11-08-2023 10:46 AM
My data and texts work.
I have done everything that I needed to and it still isn't working.
I am in the USA, my husband's phone is also with Public and his works fine.
11-08-2023 01:00 PM
Did you newly activated? In that case call Tellus CS they'll remotely help you
11-08-2023 11:32 AM
I gotta scratch my head, wondering what the reasoning is for PM to not turn ON volte on all volte phones...not just a small list. They've re-intro'd those Canada / US plans so they know snow-birds are demanding service while in US. 🤔
11-08-2023 11:20 AM - edited 11-08-2023 11:28 AM
Do you know if your phone has been enabled for volte here yet? If not then your only option is connecting to T-Mobile and hoping it will switch down to 2G GSM for calls. Or you can change down to 2G GSM manually. But then it's still a matter of coverage. Talk and text will work on 2G GSM. Data and text works on 5G and 4G LTE on T-Mobile and 4G LTE on AT&T.
What's the make and model of the phone?
11-08-2023 10:58 AM
try turning off 5G in the settings and select LTE or 4G....then try your call again.
11-08-2023 10:55 AM
Yes, I have the US Canada plan
I have done all that and have seen the AT&T on my screen but still wouldn't work.
I will try again. Thanks
11-08-2023 10:52 AM
did you get the talk/text/data add-ons ? If so, you might not have a volte enabled phone. The raoming talk portion has been degraded to US retiring their 3G service. Without volte enabled, you're restricted to using their 2G service and it's not a very good experience in most cases now. What make / model is your phone ?
11-08-2023 10:49 AM
@Geena1399 - do you have a Canada/USA calling plan, or the correct Roaming addon with calling included purchased?
Try restarting your phone, or preforming a reset of the device's network settings. This can help you get connected to the proper network.
After you do above, do you see AT&T in your network options of the device?
