07-15-2022 11:42 AM - edited 07-15-2022 11:43 AM
For about a week now, I can't receive or make calls unless I switch my S22 Ultra phone to 3G when I'm at home. I'm in Toronto, leslieville.
I've always had a relatively weaker signal at my condo, but had no problems with calls.
I reset network settings, but no help.
I noticed the dBm when I'm on LTE is -120, while on 3G is around -83. On LTE, I have 2-3 bars, while on 3G I have 4-5 bars.
Can anyone suggest something? I'm still on a 3G speed plan. Thx.
07-15-2022 12:50 PM
@zaptor99I am sure others can explain better then I but instead of switching to 3g for a voice call it will soon be voice over lte there will be no using 3g anymore for calls
07-15-2022 12:43 PM
@RossN Can you please elaborate on how VOLTE fixes this issue? It seems I don't have a strong LTE signal in my area?
07-15-2022 12:40 PM
Definitely hope this will happen.
07-15-2022 11:53 AM
@zaptor99 Unfortunately this issue is happening to a lot of people hopefully when VOLTE comes by early September this issue will go away
07-15-2022 11:45 AM
Interesting. I'm having a similar problem also on a Samsung. But my problem is limited to incoming calls just from Public customers. Everything else works fine while sitting on LTE. Changing to 3G made no difference.
The interesting part is that we both have Samsung's.
