Incoming calls
07-15-2022 11:57 AM
Hi I can’t receive incoming calls. Outgoing work. Incoming don’t ring and go to voicemail. I have restarted phone. Cleaned sim. Toggled airplane mode. And made sure I’m not blocking any incoming calls. My texting works and my data seems to work. I’m worried my sim is hacked. Is there a way to talk to a mod. Thanks
Service
07-15-2022 12:52 PM
I had a setting in my phone where it blocked certain calls (from unknown numbers, or from international numbers) - maybe this might be a setting to check out?
07-15-2022 12:22 PM
I don’t have an option to select 3G only an option to turn off LTE when I do that I loose my public mobile service. I mean it shows no service on top of my phone
07-15-2022 12:18 PM
Ok I’ll try
07-15-2022 12:00 PM
Hi manually change your network settings to 3G that seems to have helped a lot of folks
07-15-2022 11:57 AM
Long time customer also.
