Can't receive calls from the US
HPDM
My phone is able to receive calls from Canadian numbers but not US numbers. The US caller was on Verizon and got the error "call cannot be completely as dialed."
Thanks!
popping
@ChuckYeah wrote:
@popping A week ago, is that possible? How often are numbers updated? I did not know they had to be.
IDK.   I think phone system is similar to the Internet.  There must be a routing table somewhere to connect to the number.
popping
@HPDM
How long you have your phone number?
Verizon system may not have the latest update for your number?
Just thinking out loud...
But you can receive a Canadian call correct? If so, my guess it's on the other end. Tell them to check into their plan? They are dialing +1, I assume.
HPDM
I can call them fine, I just can't receive their calls. I activated about a week ago.
ChuckYeah
Did you get your 400 min Holiday gift?
Try calling them and see if that works. How long since you signed up?
