04-15-2022 03:24 PM
04-15-2022 05:15 PM
That's the "Peace of mind" setting! Sorry, I couldn't resist.
04-15-2022 04:39 PM
unnecessary repetiion
04-15-2022 04:18 PM
Did you just activate your account and port in your phone number? Are you recieving any incoming calling?
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #
04-15-2022 03:43 PM - edited 04-15-2022 03:44 PM
@Chris-g35 When did you join PM? What is make & model of your phone?
04-15-2022 03:36 PM - edited 04-15-2022 03:37 PM
Maybe.... she's just not calling you. 🤔 (don't mean to imply anything by that...)
Presumably, you can receive calls from other people, and when she calls other people, they can receive her calls... do a test to check those possibilities.
04-15-2022 03:36 PM
@Chris-g35 - if she has the setting on her device to only accept calls on from contacts that exist on her contact list, then have her add you as a contact (if you are not there already); or get her to turn that setting off completely.
04-15-2022 03:32 PM
Did you accidentally block her? Are the calls going directly to voicemail? Can you tell her to dial your number using the dialer and put a 1 in front?
