02-06-2020 09:08 PM - edited 01-05-2022 09:23 AM
Hello,
I'm hoping someone can help.
As of this morning, I am unable to make outgoing calls. I have the $15 plan with 250 mb + 1GB bonus and 100 minutes. My account is paid current and I have not used all my minutes. I am trying to make a local call and get a message stating not covered in plan.
I have restarted phone, turned off and on, reset the settings, but nothing works. Incoming calls are ok. Data works. Texts message works, just no outgoing calls.
Please help!
06-05-2020 09:29 PM
To save minutes on checking voicemail you can do the following as suggested by @gblackma in another thread:
I'm on the same plan and to save more, add the TextNow voip app and use it via Wifi to make / receive / send calls and texts in Canada and to the United States for free. You can also use it as I do to check my voicemail from my own phone without using the minutes from the PM plan. Simply dial your PM phone number - reject the call when it rings (this sends the call to voicemail) - press the * key to allow you to enter your password. - enter - and you are in your voicemail account - Hang up when you are finished. No minutes used.
06-05-2020 09:22 PM
Awesome reply. Thank you! I to was having this same issue. Guess all 100 minutes was used up. Strange they just disappear rather than showing 100/100 used.
Great news to hear of the $5 for 500 minutes top up - which DOESN'T EXPIRE!! Expected that to be per month! These replies were valuable and much appreciated. Thank you.
02-06-2020 11:21 PM
You should have received a text from 611 saying that you have 10 minutes left.
The $5 add-on is a terrific deal for this plan (and the obsolete $10 plan).
02-06-2020 10:47 PM
@mobileguy wrote:I also have the $15 plan but don't have the 1gb bonus. Was that an older plan that was being offered?
No, that 1GB bonus wasn't an older plan, but was a Holiday Giveaway that PM did before Christmas - it was 400 Long Distance minutes, and 1GB of data. I signed up shortly before that, and got a couple of freebies right away, so the timing was pretty good on that. 👍
02-06-2020 10:22 PM
@lubna46 Always a good idea to have a moderator look into whether your outgoing calls are being properly accounted. Did you receive a text message warning you were at 90% of minutes used? If not it could be a sign that there is an issue. But as suggested the $5/500 min add on is incredibly cheap and eliminates the frustration of running out of plan minutes. It stays on your account until it runs out so it's great insurance that can last a year or more depending on your usage.
02-06-2020 10:11 PM - edited 02-06-2020 10:19 PM
The following information is off the help article:
Making a call | Calling *611 (the IVR) |
Answering a call (not $15 plan) | Making or receiving calls from 911 |
Retrieving voicemail messages | Using calling apps when connected to Wifi |
Using call forwarding |
02-06-2020 09:59 PM - edited 02-06-2020 09:59 PM
This makes more sense. Possibly more than allotted minutes if I look for past 30 days. Thanks. I have messaged moderators for confirmation.
02-06-2020 09:33 PM
Usually the counter is accurate but things do happen. Contact moderators to check it.
In a meantime download TextNow app and you will have unlimited calls to USA and Canada, restrict background data.
Another option is to download hangouts dialer and set yet number as outbound caller ID, most of people won't even know you didn't call from your cell, call qualities is not bad at all
02-06-2020 09:23 PM
@lubna46 just one more thought. The minutes are not month to month. The plan is 30 days..so you have to calculate your minutes used from last payment date to present.
You can do this by logging into your account and under "change plan* click "view my usage".. it will show you all calls, text, data that has been used.
Double check that and if it still does not add up. Then moderators will have to look into it.
02-06-2020 09:22 PM
Yes, rounded up.
02-06-2020 09:21 PM
@lubna46 wrote:It doesn't show minutes under data/add ons, but I reviewed my log and it only adds to around 30 minutes.
Did you round all calls up to the next minute? As stated everything is rounded up so 4 min 5 seconds is 5 minutes
02-06-2020 09:20 PM
403. As mentioned on my post, making local call to 403 area code
02-06-2020 09:18 PM
You will have to contact Moderators then to look into it for you.
Or private message at link below.
02-06-2020 09:15 PM - edited 02-06-2020 09:22 PM
@lubna46 If you have used up all your minutes the 500 minutes for $5 Canada wide addon is a good one to get. Its a 2 step process to buy it , add the funds then purchase the addon.
Your calls are counted by the minute ie a 1min 2second call is counted as 2 minutes and voicemail calls also count against your 100 minutes.
02-06-2020 09:15 PM
02-06-2020 09:15 PM
02-06-2020 09:13 PM
@lubna46 wrote:Hello,
I have restarted phone, turned off and on, reset the settings, but nothing works. Incoming calls are ok. Data works. Texts message works, just no outgoing calls.Please help!
@lubna46 , what is the area code for your PM account and what area code are you trying to call? And where are you located when trying to make this call?
02-06-2020 09:11 PM
Log into your account and scroll down to My data and Add-ons.
Does it show you any minutes there? Like 54 minutes of 100?
If nothing is there it means you used all your minutes..
02-06-2020 09:10 PM
You are sure you haven't used up all of your calling minutes? If you log into the self-serve check under add-ons you should see Canada wide calling **/100. If there is nothing there you have used up all of your calling minutes
