Can´t make or receive calls
07-21-2023 09:32 PM
Hi!
I just switch devices, and I can´t make or receive calls. After trying to make a call, it says "Network busy" and hangs up. If somebody tries to call me, the call doesn't connect. I already put the mobile in airplane mode, checked the APN and everything is good.
Can anybody let me know how can I resolve this? @J_PM
Thank you!
Service
11-02-2024 02:02 PM
Same issue, over the past several months (at least). Restarting the phone fixes it, but only for a few days/ a week. I don't get any voicemail if someone tries to leave them.
11-27-2023 12:07 PM
I have the same issue. I have done all the troubleshooting and checks. Everything is as it should be but nothing has helped. Can't even send a ticket because all the links I'm provided by the bot return a 404 error. Not leaving me with much choice here.
07-22-2023 03:31 PM
Hi!
Thank you for your help.
I tried with the steps you provided me, but it´s still not working. If I try to select 3G only it doesn´t detect any network other than Rogers. In my previous device, it detected Public Mobile. If I choose 4G, I can use data, and messages, and even I get the notification from voicemail, but I can´t call the voicemail.
My device is OUKITEL C33, according to the website, it can be used on 3G/4G/LTE. But I can´t find the option for VOLTE.
THank you.
07-21-2023 10:04 PM
@Joceof86 I hope you rebooted the phone at the least. Are you able to text or use data? How is the signal strength? If it's a very old phone, make sure its not locked to any carrier.
07-21-2023 09:34 PM
your phone clearly connected to PM? does data work?
Try this
- first try to reboot the phone
- If that does not work, change the Preferred network type or network mode to 3G only or WCDMA only and see if it works
- Try to click Reset All Networks and see if it helps
- and do you have another phone to test the PM sim ? just to make sure it is not a device problem. Also, that can force a sim card re-provision and it could resolve the problem
- Also, try the phone in another area if possible, it could be just a local network outage
- You can also try to see if VoLTE works. But first, what brand and model of phone you have?
You can check the VoLTE compatibility here: https://www.publicmobile.ca/en/on/get-help/articles/volte
If you have a compatible one try to turn on VoLTEiPhone: Likely no extra work need to do as Telus will enable by default but hide the option. Still you can check
Settings->Cellular->Cellular Data Options->Voice & Data, enable 4G or LTE there
Pixel: Likely no extra work need to do as Telus will enable by default but hide the option. Still you can check
Settings->Network and Internet->Internet, click on the settings icon besides SIM 1, turn on 4G calling there
Samsung/ Other Android: Settings->Connection->Mobile Data, enable VoLTE thereNow, turn off Wifi first. Check if the phone status bar showing it is connected to 4G or LTE
Then make some calls, see if the signal indicator shows LTE or drop back to H or 3G while you are on the calls. If it stays with LTE, then yes, you are using VoLTE, and you can see if calls are any better.
