Can't make or receive calls or text messages
11-27-2016 04:22 PM - edited 01-04-2022 01:18 PM
Phones
09-28-2018 09:40 PM
It might need a factory reset like the LG phones...That is the only thing that fixes the APN settings
09-28-2018 07:19 PM
try doing a hard reboot/battery pull. also, try popping out the sim and putting it back in.
good luck!
09-28-2018 06:39 PM
11-27-2016 05:15 PM
11-27-2016 04:39 PM
11-27-2016 04:35 PM
Just curious, what handset are you using?
11-27-2016 04:34 PM
What is your plan?
Talk/Global Text and Data?
Just trying to help you figure out issue
11-27-2016 04:31 PM
11-27-2016 04:30 PM
What plan do you have?
IF U have NO Talk plan, then that's why, BUT If U have Talk in your plan, then try rebooting your handset to see if that works, if Not, Then a PM Mod must access your A/C to check and correct
