05-02-2018 08:55 PM - edited 01-04-2022 04:12 PM
05-03-2018 08:49 AM
Good morning @bev01,
thanks for taking the time to post on our community !
I'm really sorry to hear about your outgoing calling issues despite having Canada wide talk. As explained by @will13am, some phone numbers may not properly be configured in your profile which causes this problem. If - even after trying to call while using a 1 in the front and power cycling your phone - the outgoing call does not work, please don't hesitate to send us a private message. We will be able to better assist you and look for a root cause and resolution 🙂
Let's keep the conversation going,
Mary
05-03-2018 04:39 AM
Please note that their hours of Operation are 7 days a week, from
By the way, when making a long distance call, make sure you have the right prefix. Unfortunately, BC has a lot of new prefixes:
This is a list of area codes in the province of British Columbia:
05-02-2018 09:18 PM
Sometimes when an account is set up there are glitches in loading the calling profile which leaves certain area codes out as part of the included calling function. This was how the problem was explained to me. Try using 1 and +1 prefix as suggested. Failing that, get the moderator team to investigate the calling issue. The moderator team can be reached via private message using this link. Refer to the following knowledge base link for information on contacting the moderator team.
05-02-2018 09:01 PM - edited 05-02-2018 09:04 PM
@bev01 I just peaked outside and it looks like BC is still attached to Canada 🙂
Have you tried dialing 1 in front of a number? Can you make a phone call anywhere else outside of your home province?
