10-04-2022 02:56 PM
Both my husband and I are having problems with Public Mobile. I can't make calls (and don't think I can receive them either because a call went straight to voice mail yesterday), but SMS and data are both working. My husband can't make calls and can't send or receive texts (not sure about internet). Anyone else having similar problems today? We're in Ontario.
10-04-2022 06:02 PM
Your link doesn't work for me. Says I don't have permission.
10-04-2022 05:58 PM
I accepted your solution by mistake. Don't know how to undo it. Also I'm EAST of Oshawa not west as I had previously indicated.
10-04-2022 05:19 PM
10-04-2022 03:12 PM
I've already rebooted my phone twice. I guess I can try taking out the sim card and putting it back in, but since we both have issues, I didn't think that the sim card would be the issue.
10-04-2022 03:08 PM
@RJN if both your accounts have issue, likely is an local outage, might be related with Oshawa's.
Try to reboot the phone once, or even reseat the sim card.
10-04-2022 03:07 PM
We're about two hours west of Oshawa in North Frontenac. I did see that Telus had an outage there but couldn't tell how far out the outage went.
10-04-2022 03:04 PM
10-04-2022 03:02 PM
I don't know what that means.
10-04-2022 03:00 PM
@RJN Did you port into public mobile?
