Can’t make calls or check voicemails
aroseadame
Outgoing calls and voicemail drops and says “call failed”. Is the network down?
aroseadame
Frustrating, but at least we’re all in this together haha. I’m also in Edmonton.
Jazminnie25
The maps isn't well populated. But it does seem to affect multiples provinces. So far no updates have been provided by Public Mobile nor Telus.
natashan
Seems that way. I'm in Edmonton and my phone is doing the same, someone also reported issues in Calgary.
@aroseadame
If you are in Alberta, yes, there seems to be 3G network problem in Alberta and affecting voice
@aroseadame  There lots of reports of outages atm. Check
Outage   map in your area:
https://istheservicedowncanada.com/status/telus/map
