01-05-2026 09:34 AM
Are there any outages in Toronto today? I can no longer make a call. When I try (iPhone) it just says Calling… and then disconnects. Worked fine yesterday. Reboot didn’t change anything.
01-05-2026 11:57 AM
We appreciate your escalation. An agent is already assisting the customer and will ensure they receive the support they need.
01-05-2026 11:06 AM
I’m having the same problem as well. Reboot doesn’t fix it.
01-05-2026 09:52 AM
no outage according to Telus site
https://www.telus.com/en/on/outages
and your mobile data is working? only voice calls have problem? what iPhone do you have? newer than iPhone 8?
try Reboot phone and Reset network settings
