01-13-2024 01:30 PM
For some strange reason I am not able to log in to my account but obviously still able to lo in to my community account. What gives?
01-13-2024 01:35 PM
This happened right after I re-set my password - I'll do as you suggest and wait 1/2 hr or so and try again --
01-13-2024 01:35 PM - edited 01-13-2024 01:36 PM
@El_Gato Did you see option for “didn’t get code “ tap it sometimes it will give option to send code to email instead . If still no luck you can use this. Direct link to support to help you gain access
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
01-13-2024 01:32 PM - edited 01-13-2024 01:37 PM
@El_Gato tried using the app?
or tried using Incognito mode?? what is the exact error message?
try to reset password first. After reset, wait 15 mins before login and hope it helps
if not, the PM support is your friend, please open ticket with the lme
