07-06-2018 07:31 PM - edited 01-04-2022 06:23 PM
07-07-2018 09:11 AM
Hi,
If you have any questions concerning your account, just send a private message through the following link:
07-06-2018 11:25 PM
Correct, I have newly registered sim card and I know my password but the system didn't recgnize it and I am not able to reset it, no email send to me.
07-06-2018 07:56 PM
@moonj86 wrote:I have a new sim card registered and the system didn't take my password..
you mean you cannot log to your self service ..
07-06-2018 07:55 PM
@moonj86 wrote:Sent a message already before I post it here, no reply yet.
hoppefully one moderator will be here and see your message, dont worry just wait and your problem will be solved soon.
07-06-2018 07:54 PM
07-06-2018 07:53 PM
07-06-2018 07:45 PM
Yes, the forgot password feature is broken atm. Only way to reset is by contacting the mod team. We have been told that PM team is working on it to bring the fix soon.
07-06-2018 07:39 PM
I suggest you send the moderator team a private message using this link.
dont forget to send also your email, phone number, pin and some details of the probleme.
they will help you to solve your problem
have a nice day
