Can't get phone call from my home phone
ZhengguoTao
I try to call my cell phone through my home phone (provided by CIK), however the call can't get through.
Sheng
ZhengguoTao
Thanks all for your help. I figured out that my cell phone number is not local number. I need to dial 1 and cell phone number from my home phone. Cheers.
@ZhengguoTao
Did you leave your old SIM in your phone and waited for a text confirming you are porting over to PM?
If you missed this most important step in completing the porting your old number. You  will need to contact CS_Agent to complete the porting so your cell phone will have PM service.
@ZhengguoTao
Check if calls to that number are still going to the old provider.  That will continue to happen until porting has completed.
will13am
@ZhengguoTao , is this a new account and did you do a number transfer?  Number transfer can take a couple of hours to complete.
