12-31-2019 08:27 PM - edited 01-05-2022 08:49 AM
I have international add-on a while ago and been using it well.
But now it seems not to work anymore with UT...something error message.
Please help me solve this issue.
Thanks,
Won
12-31-2019 09:49 PM
12-31-2019 09:48 PM
12-31-2019 09:44 PM
Awesome, I hope you don't feel bad about it. It's just ettiquette I've found out since I joined. If you hang around the community some, you'll learn a lot more and never know everything. Again, welcome!
12-31-2019 09:39 PM
12-31-2019 09:31 PM
See, I told you, lol. If you can't figure it out just leave it as @NDesai says.
12-31-2019 09:30 PM
@NDesai would not be concerned. Just go back and edit your post and remove the solution and then reassign the solution.
Worry, not. This was merely a learning opportunity for you and every other new PM user that may stumble onto your thread. Welcome!
12-31-2019 09:30 PM
@wonmyung wrote:
Sorry, I didn't know well how the credit works here since it's second or third time for me to use the community for problem solving. But it wasn't intentional. I can definitely give the credit to @NDesai if there's way to do that. I don't really care about the credit 🙂
I got hint from @NDesai link but I had to find out what the exit number on Google.
Sorry for the credit! Please let me know if you know how to redirect the credit to you.
Thanks all.
@ChuckYeah @wonmyung It's fine how it is. It is possible to give yourself a solution as long as no one else mentioned the solution and it was not so obvious.
12-31-2019 09:25 PM
Thanks all.
12-31-2019 09:08 PM
@wonmyung wrote:Yea...
That's what I've known so far and why I've been doing without it.
I'll try without it later again and see how it goes.
Cheers!
May be it was the phone or the dialer app feature that would auto dial the correct exit code (011) based on your local number or country?
12-31-2019 09:07 PM
@wonmyung It's frowned upon in the community to mark your own answers as a solution as this is a site looking for help. However, if you did find your own solution that's great.
If you did look at the link provided by @NDesai and it gave you the answer, you should credit NDesai with the solution.
No big issue, just an FYI.
12-31-2019 08:55 PM
Yea...
Cheers!
12-31-2019 08:51 PM
@wonmyung Hmmm....strange it worked before without 011. Usually that's a given with overseas calls.
12-31-2019 08:48 PM
Haven't, but I figured it out.
I used to use this
+82(country code) + city code + phone number.
And it worked so far, but doesn't work anymore.
So I tried like below and it worked out.
Dial 011 + country code + city code + phone number
Thanks all!
12-31-2019 08:42 PM
@wonmyung Have you tried my suggestions yet?
12-31-2019 08:37 PM
1. I still have 299/400mins on my account AND free added another 400mins left.
2. Multiple numbers don't work either.
12-31-2019 08:35 PM
@wonmyung wrote:Calling to South Korea. And as I mentioned, I've used it so far and recently and suddenly it didn't work.
Is it just one number or multiple. Are you able to dial it using another LD service?
12-31-2019 08:34 PM
Any chance you have used up your international minutes.
Log into http://selfserve.publicmobile.ca and see if it's showing ### / 400 or if it's disappeared which means it is used up.
12-31-2019 08:31 PM
12-31-2019 08:31 PM
@wonmyung What error message are you getting? Try rebooting phone. If that doesn't work turn airplane mode on. Wait 10 minutes. Turn off. Reboot. Try calling again. Working?
12-31-2019 08:29 PM
@wonmyung Which country are you trying to dial to? There are only 18 countries you can dial a number to.
