07-10-2025 12:08 AM
Hey I’m looking for help with my account, I can’t confirm my identity when they send me a code to my phone number, it’s the correct number but I still can’t get a code and therefore can’t login to my account, can you please help.
07-10-2025 11:24 AM
hank you for the escalation!
The customer is already in contact with an agent.
07-10-2025 01:02 AM
self solution removed
07-10-2025 12:56 AM
Y’a it didn’t work, Alr I’ll surely do that, thx for the help
07-10-2025 12:46 AM
I'm guessing that didn't work for you either? Then you will need to open a ticket using the orange text bubble on the bottom right or use the link below to contact PM for help
07-10-2025 12:33 AM
Y’a I tried that but it just gives me the option of getting a voice message
07-10-2025 12:11 AM
Under where you enter the code you should see did not get code. Click in it and get code sent to your email
