Tuesday
Followed the process of transferring number from Koodo. Said "yes" to their text to confirm transfer. Then app said something went wrong with activating the subscription, but I got an email saying it was activated but no info on the temporary number. Tried to use the "get support" option but logging in just leads to a white screen. Tried to get support on PC, and it wanted to confirm my identity by sending a code to my phone #, and code won't send. How do I find out my temporary number? And will the public mobile app fix itself once the number is transferred fully?
Wednesday
@SarahOu wrote:I logged out and back in to the app and now it says my subscription is active. Just not sure how the temporary number works, if someone needs to text me does it just redirect to it or do I have to tell them what it is?
You're best to think of there never being any temporary phone number because in all cases, the number is replaced as soon as any number port in is requested regardless of whether porting has completed.
Tuesday
did you request porting in the number? there is no temporary number in this case. Your PM phone has the number you want to port in already. It can make outgoing call and text and data would work
but incoming calls would work only after the port is done. You got a message from your old provider asking for your approval yet? you replied Yes? If you replied yes, wait another 2 hours, reboot the phone with PM sim card and incoming calls should work too
Tuesday
Tuesday
are you activating eSIM or physical sim card?
test your sim card if it is physical, see if it connects to the network. But if it is eSIM, check your phone's SIM Manager screen to see if the eSIM installed, enable it and test
but if that is not working, ask PM to check. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
Tuesday
You can message them at the link below for assistance.
The app should work. Are you able to uninstall it and reinstall.
