Can't complete 2-step add-on purchase
hexenkunst
I purchased $30.00 of funds to add 1 GB of data to my plan. I am aware of the two-step process and tried to purchase it through the funds, I got the "good things come to those who wait" loading message and then it refreshed the page and the 30.00 are still showing up in my funds. The data add-on was not added. I tried doing it twice and this happened both times.
The error message I got at the bottom of the screen says "ValidateAndUpdateOptions/Provisioning_15"
Am I missing anything? Thanks!
Rockdaddy22
Awesome, thanks for the update 🙂
hexenkunst
The above solution worked, I was able to have it update in a different browser.
Thank you!
Rockdaddy22
Please keep us updated on this issue
srlawren
@hexenkunst I'd start with what @xCameron94x suggested since that's pretty quick and easy to try.  If you're still unable, please send a private message to @CS_Agent for assistance and they will help out as quickly as possible.
xCameron94x
try using a different browser, clearing your cache or try doing it in incognito mode
