10-07-2023 01:20 PM
10-07-2023 02:02 PM
In order to finish the activation you will need to download the Public Mobile app. If you’re already using the app and unable to login I would try clearing the browser data from your default browser on the device and then delete and re-install the app.
If you continue to have issues activating there is a live chat that is specifically for new customers trying to activate:
https://services.telus.com/chat/publicmobile/chat-pm.html?portal=publicmobile&language=en
10-07-2023 01:47 PM
@Mikola2 are you using the app?
if already using app? submit ticket with CS agent for help to update sim card number
10-07-2023 01:38 PM
@Mikola2 wrote:During activation yesterday, got message Esim not compatible, today went to store bought sim for $10 instead of five, but can't resume activation.
You may need to resume activation on the PM app.
Afterwards, you can contact customer service agent. CSA will likely credit the $10 to your account in available funds.
10-07-2023 01:37 PM
And resume activation just keep running circles. Log in doesn't work ether.
10-07-2023 01:34 PM
10-07-2023 01:28 PM
More details would be helpful. What happened?
Unfortunately, there is no live chat or phone number to call. You would need to submit a ticket for customer service agent help or directly private message CSA. However, it usually takes a few hours to respond. Maybe if you can provide more details, the community members (customers like yourself) can offer advice to get your activation going.
