07-13-2020 03:22 PM - edited 01-05-2022 12:05 PM
hi there, i can't reset my login password - reset email never arrives and its not in spam.
Account has been locked out, can you please help?!
07-13-2020 03:24 PM
If activated in store, you should attempt the creation of a self serve account here: https://selfserve.publicmobile.ca/self-registration/.
First, try the account reset function here: https://selfserve.publicmobile.ca/forgot-password/.
If that fails, you will need to submit a ticket. To get a ticket: click https://publicmobile.ca.ada.support/chat/ and enter your question into SIMon. Follow/invent prompts until you get to the Contact Us button, click it and a Submit Ticket button should appear.
If you are having problems using SIMon contact the moderators directly through private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 In theory this takes longer than using SIMon.
