Can't Port a number error on webpage PLEASE HELP!
matthewdchin
I want to activate a sim card and port in a number but i get stuck on the 2 Phone number page. After filling out the information I press process button and the page hangs and i get a website that says
Generic Error
Oh no!
It looks like something went wrong, but don’t panic.
Log out and then log back in again to continue. Or return to the Login Page.
I have tried several times but each time it says the same thing. Someone please help!!
9 REPLIES 9
matthewdchin
Thanks I re entered on chrome browser and it works now. Thanks for all the responses !
popping
@matthewdchin wrote:
I tried but still didnt work. now shows up as Invalid SIM
Put your PM SIM card in your phone and restart your phone to check whether it was activated or not.
I believe that as long as the error didn't happen afte the payment page, you might still be okay.  For now I would clear the browser's caches, close the browser, and then trying in about 30 minutes to an hour.  If that doesn't work, you'll have to contact moderators to complete the failed activation or to possibly find a way to get that sim card replaced.
matthewdchin
matthewdchin
I opened up a new browser and entered the info again. At first it said I have to wait 50 mins for session to end because my sim number is used in a current process... Then after I waited 50 mins. The message now says my sim number is invalid....
not sure what to do
popping
@matthewdchin
Restart your browser after getting any error from PM self-serve portal because it does not clean up the session error properly.  Restart your browser will ensure starting a new session.
sandpublic
Generic Error
Oh no!
During activation are you choosing a new number or trying to port your existing number? The safest way to do it is to select a new number (temporary) and then do the port later after the activation goes through and you account has been setup.
matthewdchin
wow thanks for the super quick response I will try that now!.
RobertQc
Generic Error
Oh no!
Clear your cache/browsing history remove all cookies associated with *.publicmobile.* and try another browser / disable add-ons / private browsing / incognito. If you are using safari / cell phone go to a real computer and if all that fails, wait an hour and try again.
If nothing ends up helping, I suggest sending a message to the moderator team. Click this to send them a message. and explaining to them your issue, but it is more than likely the above steps will solve your issue.
