09-11-2023
09:36 PM
09-11-2023
09:38 PM
computergeek541
I need someone from public mobile to resend a phone number transfer request ASAP.
11-22-2023 01:29 PM
Using a computer, *not cell phone!*, select My account and login. On the left hand side select My Profile. On the right hand side scroll down until you see Transfer My Number. Click that and beging the process. Make sure you are still using your old sim card/network when you respond to the old network by text about transfering. I figured this out with zero help from public mobile as there is no human to speak with and the chat bot/creating a ticket was unfruitful.
09-11-2023 10:46 PM
Or on mobile, tap your palm tree avatar and then tap on Messages.
09-11-2023 10:10 PM
09-11-2023 10:09 PM
I can't find my community inbox?
09-11-2023 09:39 PM
hi @ClaytonR
porting into PM?
you have to contact porting team, I will send you the number to your Community inbox. Check it and call
09-11-2023 09:38 PM
@ClaytonR wrote:I need someone from public mobile to resend a phone number transfer request ASAP.
Please open a ticket using the chatbot.
If trying to submit a ticket using the chatbot results in an error message, send a private message to CS_Agent.
