Can someone help me.
Denwong
It's third day now I got no response from pm
How can I send a private msg to a
Mod?
I have sent 3 emails but no response
Please help me. I even want to give up porting my
Number and use a new number but Rogers can't cancel because a port requested is needed.
18 REPLIES 18
Rockdaddy22
Shaz definitely is one of the best, glad everything worked out 🙂
lukevader
Just want to say thanks Shazia for fixing my wifes phone. Dont want to tag or pm you back cause you are probably very busy but if you happen to come across this post.......... thanks. Heart
Shazia_K
Retraité / Retired
Retraité / Retired
Hello @lukevader
I sent you a private message please reply to it once you get a chance.
Thanks,
Shazia
@Denwong  best way to get your problems fixed is not spam the forum.  You have 3 posts in the last hour alone.
Have a look at this post:
http://productioncommunity.publicmobile.ca/t5/user/viewprofilepage/user-id/48
Look for "Send this user a private message" on the right side under Contact me.
Jeremy usually does not fix tech issues... I am guessing that is why you pm him?
Denwong
But site telling there is no one by that name
Did I do something wrong??
oilblue99
For the Mods names and more, see:
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/All-you-need-to-know-about-our-Communit...
Note that a private message to a Mod goes into a pool they can all see, so no need to message them all.
Hope that helps.
edit:
How to create or view Private Messages
Denwong
I don't know how to msg a mod.
Help me please it's been 3 days I want to know what to do about my porting problem with Rogers
lukevader
In other words denwong if you just accept a pm number your problem might not change.
Rockdaddy22
Yes there are different kinds of issues not just failed ports.
lukevader
@Denwong honestly it's not just the port problem here. I activated a new sim with a new phone number from PM and I'm STILL in the same boat as all you stuck porters. NOTHING works on my phone. No inbound or outbound phone calls or texts except inbound texts from "100"
neo911
@Denwong you send a private message to the moderator by clicking on their username. then on the right hand side you will see 'Sent this user a private message'.
ShawnC13
@Denwong  How far are you into the process?  Do you have any service on your PM SIM?  Was there any error you got when trying to do the self serve porting?
mimmo
Does your old sim card from rogers work?  Use that until the PM port goes through.
MoreYummy
Add a tag in your message such as @Shazia_K
You dont cancel the port request, after your port is completed, your service at rogers will be cancelled.
