11-24-2016 11:32 AM - edited 01-05-2022 12:54 AM
11-24-2016 11:47 AM
11-24-2016 11:42 AM
PM i believe will adjust your billing cycle to when the port is complete. this means you will not be paying for two services. your old provider will prorate your last bill.
11-24-2016 11:40 AM
Glad that old number works.
What exatly is your situation?
What number shows up when you call out from you PM sim?
my suggetsion in most of teh above would be to use your old sim and messge the moderators with your porting issue. you dont want to start porting.repoeting a number might cause bigger issues.
11-24-2016 11:38 AM
11-24-2016 11:35 AM
