01-14-2022 09:50 PM
Hi. I am a new customer and got my account activated just now. I had inserted a referral code but I do not see the $10 credit on my account. I would appreciate it if you could help me with this issue. Thank you so much.
01-14-2022 09:55 PM - edited 01-14-2022 09:56 PM
@Vida1 , yes you can still ask it now as long as it was an honest mistake. Just enter a ticket with PM support now:
**Monitor your Community inbox, envelope on the top right, after ticket is opened. CS Agent will reply and work with you via messaging there
01-14-2022 09:50 PM - edited 01-14-2022 09:53 PM
@Vida1 wrote:Hi. I am a new customer and got my account activated just now. I had inserted a referral code but I do not see the $10 credit on my account. I would appreciate it if you could help me with this issue. Thank you so much.
@Vida1 the $10 can take up to 72 hours to show up in your available funds area.
EDIT:
If after 3 days, and it does not show up, you can always inquire about this with the Customer Support Team, methods to reach them here: https://www.publicmobile.ca/en/on/get-help/articles/contact-an-agent
01-14-2022 09:53 PM
I am not sure if I had inserted the right code. How can I ask the service support to add that to my account?
01-14-2022 09:55 PM
@Vida1 wrote:I am not sure if I had inserted the right code. How can I ask the service support to add that to my account?
@Vida1 you will know if you used the right code, if you asked the friend whose referral code you used if they are showing the $1 from your using their code.
Your last four digits of your phone number should also be showing on their account.
So check with them first. Or wait 72 hours, then if nothing contact CSA by link provider previously.
01-14-2022 10:00 PM
to you will receive a one-time credit $10..,,they will applied within 3 to 5 business days.
after 5 days if you not showing at your account then you need to Contact Customer Support Agent by CS_Agent, and Explain your issue to them can solve your issue, they are nice Service Team they will help you 100%.
Here’s How To Contact Customer Support Agent,
Good Luck....
01-15-2022 12:34 PM
