04-29-2019 10:22 PM - edited 01-05-2022 07:21 AM
05-30-2019 06:14 PM - edited 05-30-2019 06:19 PM
Usually info mismatch if denied
I have no idea if you are both related since you also having issue with port but do NOT send me your personal info I don't work here
@gduval wrote:porting refused by rogers! need help with porting my number
05-30-2019 05:35 PM
@gduval wrote:heeeeelp!
Did you contact the moderators?
Was your Rogers account active when you tried to port? If not then porting only works with active accounts.
Do you still have an outstanding balance owing them for maybe a newer phone? They might want that squared up before letting you go.
05-30-2019 05:29 PM
heeeeelp!
05-30-2019 02:17 PM
What are you having issue with ? I did it a few days ago no issues
05-30-2019 02:07 PM - edited 05-30-2019 02:08 PM
@gduval Though I'm unable to suggest any possible fixes to your porting issue, it might be that you may need to speak with a moderator. To do so, you can use this link:
They do take anywhere from a couple of hours to a couple of days to respond, however, so you may need to be patient if this issue requires moderator assistance.
Perhaps other community members will have other ideas for you.
05-30-2019 02:05 PM
Have you tried clearing all field and trying again? Also, are you just giving the required info or some extra info like pin etc as well? Mine did not work as well the first time but when I filled in my pin as well it went through the next time.
05-30-2019 01:54 PM
need help with porting. rogers denied.
05-30-2019 01:52 PM
05-09-2019 06:02 PM - edited 05-09-2019 06:03 PM
@Ruby2 First, try the account reset function here: https://selfserve.publicmobile.ca/forgot-password/.
05-08-2019 09:00 PM
I forgot my security question
04-30-2019 03:32 PM
@Parkbench13 wrote:dual sim phone
neither origional sim nor replacement sim working
different provider sim works fine
settings correct
phone reset same result
any other ideas?
@Parkbench13 based on your various replies I'm going to guess you have an activation issue. The replacement SIM definitely would not work as you weren't able to do the SIM swap in your self-serve account as you don't have one set up. You can't do eihter of the workarounds the community suggests for activation issues since you don't have access to your self-serve account. You're going to have to private message the moderator team as noted above (if you haven't already) and wait for assistance, unfortunately.
04-29-2019 11:16 PM
dual sim phone
settings correct
any other ideas?
04-29-2019 10:38 PM
Thank you.
04-29-2019 10:37 PM
Hi, I purchased a SIM 2days ago. Registered and activated fine. Wake up this morning and my phone says no SIM. Went through thorough settings and reboot check, still no SIM. Went to retail point of purchase for help. Same result. The retail gave me a new SIM to change over too but I had not confirmed or initiated my account via your email. No access to account self serve without text code, which I obviously cant receive to enter...
04-29-2019 10:35 PM
@Parkbench13 While you're waiting, why not describe the problem? Perhaps, we can assist you.
04-29-2019 10:24 PM
Send a private message to them.
Moderator can be reached at
