01-23-2018 06:53 PM - edited 01-05-2022 03:57 AM
Every SINGLE day I get MULTIPLE spam calls to my PM number. I've already blocked their numbers but they ALWAYS LEAVE A ****ING VOICEMAIL that I can't disable. Please help me disable voicemail entirely. Thank you
Service
08-13-2018 04:34 AM - edited 08-13-2018 04:35 AM
A couple of alternatives:
- Disable VM through the Call Forwarding options on your phone. Read the following: https://productioncommunity.publicmobile.ca/t5/Discussions/Disable-Voicemail/m-p/178587#M53620
- Extend the ringing time as long as possible. Read the following: https://productioncommunity.publicmobile.ca/t5/Discussions/Disable-Voicemail/m-p/178587#M53620
HTH
01-31-2018 05:02 PM
If anyone is discovering this thread and wants to know how to set up the extended absence greeting and prevent people from leaving you mesages, I outlined the steps here last week: https://productioncommunity.publicmobile.ca/t5/Getting-Started/Re-Disable-Voicemail/m-p/213805/highl...
01-31-2018 04:49 PM - edited 01-31-2018 04:57 PM
You may be able to help those who ligitimately want to get hold of you. Your message could say something to the effect:
"This voice mail is not in service. Please send a text to same number if you need to leave a message"
On a related point, I cannot find any Knowledge Base article or something similar that outlines all of the various VoiceMail functions and features. Is there one?
01-31-2018 10:31 AM
@kkum great to hear. It was not my method per say but one i remembered seeing being suggested in the past.
Glad it is working.
01-31-2018 10:23 AM
It's been a week and so far I haven't received any spam voicemails. I think your method actually worked! Thanks for the help.
01-24-2018 10:11 AM
Yea I thought about that but it'll be a huge pain. But I'm at a point where if none of these other methods work I might just have to use this one.
Thanks
01-24-2018 09:55 AM
maybe a last resort option would be to change phone numbers?
01-24-2018 09:39 AM
01-24-2018 01:15 AM
On some phones, you can install an app that will automatically answer the call and then just hang up on the person. For example, in Android one such program is called No Spam No Voicemail. The app itself is a little buggy (default settings don't work for me), but after tinkering with the settings, this app will answer a calls from specified phone numbers after one ring and then hang up on them. If that app isn't to your liking, there are others available as well.
01-23-2018 08:13 PM
Thanks, I think I got it working now. Let's see how this works out, I'll keep you posted.
01-23-2018 07:45 PM - edited 01-23-2018 07:47 PM
@kkum you need to select an extended absence greeting vs the regular greeting.
The option is in there some where.
Will see if I can find instructions in the forum.
Edit productioncommunity.publicmobile.ca/t5/Discussions/Unable-to-disable-voice-mail/m-p/127987#M41676
01-23-2018 07:30 PM - edited 01-23-2018 07:34 PM
Hi @mimmo
I'm trying this right now. So I'm using a greeting of straight nothing for as long as I was allowed (around 90 seconds) but I'm curious how this will prevent them from leaving messages. Since they're all bots, won't they just wait out my greeting and then leave a voicemail regardless? Thanks for helping
I will be sure to try your method next.
Thanks for replying
01-23-2018 07:05 PM - edited 01-23-2018 07:05 PM
Hey @kkum,
I remember this question has come up several times in the past. The answer is no unfortunately.
I have used YouMail in the past to handle voicemails. They email you or you can open the voicemails in their app. Delete without listening from the app or email is a lot easier and you avoid the persistent voicemail notificaiton on your phone.
You can also achieve this by enabling conditional call forwarding to your Fongo number.
01-23-2018 07:00 PM
You can not disable voice mail but you can put an extended absense greeting.
This will disable the ability to leave messages and can you record a message with nothing.
It's the best option.
