06-21-2017 10:59 AM - edited 01-04-2022 01:55 PM
Greetings all,
I'm on the Fall 2016 promo plan and thus only have provincial calling included. I've purchased the $8 add-on for the odd time I need to call outside my province or venture outside of it.
So far, I've used 38 of the included 200 minutes.
Questions:
1. What happens when I reach 200 minutes and the call is still active? Does it drop without warning? Do I get a voice prompt (if so, can the other end hear it too)?
2. Depending on how the system behaves for #1, what are the drawbacks if I was to purchase another $8 / 200 minute add-on? Am I even allowed to stack the same add-on on the same line?
06-21-2017 11:49 AM
06-21-2017 11:46 AM
@DragonSpecV wrote:Maybe it works just like a calling card? Once the minutes are up, it gives you a notification on your call, and cuts it out.
It's apparent you monitor your minutes, so it's good to be aware, and top-up when needed (like 2 minutes left) if you talk longer than a few mins at a time.
This is not my line that needs the add-on (I'm happy with Hangouts).
This particular end user needs the convenience of direct dialing to the US. They do not monitor their account online or want to have to deal with anything related to the service itself. It just has to work ... patience meter is always at zero!
06-21-2017 11:42 AM
06-21-2017 11:12 AM
06-21-2017 11:08 AM
I have 198 minutes remaining after almost 12 months... I have no clue what to expect either.
If it's like a data addon in operation, there will be no notice - just a drop of service as you no longer have it available.
Other than that, we need someone to help us understand what happens.
