Can I still make phone calls & use data at Calgary
05-16-2023
11:19 PM
05-16-2023
11:26 PM
computergeek541
Hi,
I will visit Calgary soon. Just wonder if my phone still can be making calls and using data in Calgary since the plan mentions Canada wide, or buy add ons to use outside Ontario?
Thank you.
Plans
05-17-2023 06:25 AM
05-17-2023 02:43 AM
As long as there is a Telus tower or Bell tower where you are going...it is all good.
05-16-2023 11:27 PM
05-16-2023 11:25 PM
@Jsmart wrote:I will visit Calgary soon. Just wonder if my phone still can be making calls and using data in Calgary since the plan mentions Canada wide, or buy add ons to use outside Ontario?
Yes, you can. it doesn't matter where in the country you use your service. No additional add-ons are required to use your plan.
05-16-2023 11:22 PM
all current plans will work while you're placing that call anywhere in Canada.
