08-07-2021 01:16 AM - edited 01-06-2022 03:03 AM
08-07-2021 06:46 AM
@DavisPoon wrote:I'm a Fongo user. Can I port over my Fongo phone number to Public?
Thanks.
See here for porting out of Fongo: https://support.fongo.com/hc/en-us/articles/212437466-Transfer-my-Fongo-number-to-another-carrier
See here for porting into of Public Mobile: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
08-07-2021 03:07 AM
@DavisPoon :Now that @softech has posted the answer to your question in this thread you created, you might as well mark his reply above as your accepted solution so this thread will be marked as solved and can also helped others in future with same question you had - simply click the accepted solution button on his post above.
08-07-2021 01:29 AM - edited 08-07-2021 01:29 AM
@DavisPoon yes you can. Please note that porting from Fongo (and other VoIP or landline) could take as many as 5 - 7 business days .
