11-29-2024 09:55 AM
Switched to public mobile yesterday everything works fine but I can’t make calls
11-29-2024 10:18 AM
I had just about same issue. Two days after joining PM I last ability to make outgoing calls and send messages. Look in settings under "Cellular" if you have two SIMS. For me it was one from old provider that was set as primary. I changed that to secondary and turned it OFF, PM was set to secondary. After I changed that to primary, my problem disappeared. In my case I wasn't able to delete old provider sim (probably due to the fact that it is physical SIM)
11-29-2024 09:57 AM
hi @Rachel59
data works? Inbound calls work and just not outbound?
try reboot the phone first, then Reset Network Settings
if same, ask support agent for help. you can submit ticket by direct message:
