07-31-2018 10:56 PM - edited 01-04-2022 06:36 PM
I tried porting my number over from petrocan mobility and it says on their end it failed, however I have my old number with my new sim card from public mobile and when I ported it on public mobiles site it said successful. I can send and receive text from only certain people and call anyone but anyone tries to call me and it goes straight to voicemail.
07-31-2018 11:08 PM - edited 07-31-2018 11:09 PM
@h3ll0 Seems like a failed port. Check your old sim card and see if you get signal.
You will most likely need to contact the Moderator_Team by sending them a private message and they will look into your porting status.
