Calls drop
04-16-2024 02:23 PM
Hello. I am have trouble where all my calls are getting dropped or disconnected after several minutes of being on a call. I have an iPhone 11 Pro Max. I restared my phone many times, checked the carrier setings, everything seems to be fine but it is still doing it. Not sure what the problem can be.
Service
04-18-2024 11:29 PM
Been experiencing the same issue. I have an iPhone 13 Pro Max.
04-17-2024 08:51 AM
Hi hTideGnow
I am in the Kitchener / Waterloo / Cambridge area.
I have already opened a ticket and so far I was advised to try my SIM card in a diferent phone, which I will do shortly, as soon as I can get my hand on another device.
Thanks.
04-16-2024 02:29 PM
HI @ErikG
there were some reports of similar problem this week. May I know which area you are at , like city?
I think support agent can check if any problem, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
