09-04-2019 11:16 AM - edited 01-05-2022 06:51 AM
Callers have been unable to leave me a voice mail message when my phone is out of cell phone coverage (ie. I've gone to the cottage or I've left the country with my phone). Callers receive a recorded message "1UT1. The client you are trying to reach is not available at this moment, please try again later". Callers are not given an option to leave me a message and do not receive my voice mail greeting.
When my phone comes back to cell phone range coverage, the voice mail works correctly. Is this how Public Mobile voice mail works? Any other phone voice mail I've used permit callers to leave me a message when I'm out of cellphone coverage.
Any help is appreciated.
09-04-2019 12:19 PM
I've never set / initiated call forwarding in the past. However, I took your advice and disabled all call forwarding options to make sure they were not on. I turned off my cell phone and called the phone. The voice mail message and option to leave a message worked as it should!
Thank you so much for the help in resolving this issue. Hope I can help others in the future.
Ken
09-04-2019 11:42 AM
@kenjcameron wrote:Callers have been unable to leave me a voice mail message when my phone is out of cell phone coverage (ie. I've gone to the cottage or I've left the country with my phone). Callers receive a recorded message "1UT1. The client you are trying to reach is not available at this moment, please try again later". Callers are not given an option to leave me a message and do not receive my voice mail greeting.
@kenjcameron Check and disable any call forwarding settings on your phone as per instructions here:
https://www.publicmobile.ca/en/bc/get-help/articles/call-forwarding
09-04-2019 11:31 AM
@kenjcameronThe error message usually indicate a provisioning problem.. you will have to contact the moderators with this link https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Describe the situation to them and they will pass it on to a tech team to look at it.
09-04-2019 11:17 AM - edited 09-04-2019 11:19 AM
That shouldn't be the case
Can you check your forward settings
When unavailable it should be set to voice mail number
Set it all to voicemail number
If it already is contact mods
