Caller ID
Kjussila
Hi, I just switched over but when someone calls me I can't see who it is. Just says unknown caller.
@computergeek541
I got “unknown caller” is from friends and family with unlisted number but their name will show if it is a listed number.
@BKNS27 wrote:
@Kjussila
Is the person calling you in your contact list?
I interpret "unknown caller" as no number showing up either, in which case it wouldn't make a difference if the nubmer was in the contact list.
@Kjussila   can you try to reseat your sim card and reboot the phone?
Try to hvae different friends to call you and see if caller id works
@Kjussila
Is the person calling you in your contact list? Do they have an unlisted number?
