Call to USA
05-03-2023 03:00 PM
05-03-2023 04:21 PM
- log into your self serve account
- tap the section called plans and add-ons
- there you can browse the add-on selection available
You are looking for the US long distance add on, which will give you the capability to call the US from Canada.
If you have a saved payment card on file, you can use it to purchase the add-on. If you don’t, you can make a one time payment or add a payment voucher to the account to cover the cost of the add-on.
If you have enough points built up from rewards, you can also use that to purchase the add-on.
05-03-2023 03:16 PM
You can add long distance calling minutes to your account for this. They do not expire and stay with you until they are all used up.
05-03-2023 03:03 PM
@Blessedinnocent , to call the US, you will need long distance minutes for US calling. Then it is just a 10 digit number call with +1 in front.
