“Call failed” When calling voicemail
loganheight
When I press my voicemail key it says call failed. I have tried going to the keypad and holding down number one to call voicemail then it tells me "error performing request,  Unknown error." Then call failed.
Mountainmaxman
did you ever have it working? or is this a new change issue?
Staliger
@loganheight go to settings of your phone, check voicemail option, there should be the option to input the number, put there your phone number. I had the same on Redmi Note 8. I had to go to Phone-Settings-Voicemail-Advanced Setting-Voicemail Number. Then, I put my number there, and could call voicemail from my phone.
gblackma
@loganheight If you  call from another phone, or voip app such as TextNow over your phone. Do you get your voicemail? And what's the make and model of your phone?
