3 hours ago
I’m trying to download the call logs for 03/29/2026–04/29/2026, but the system is not allowing me to download them. When I click the download button, nothing happens and the pop-up does not appear.
2 hours ago
it helps to try using a different browser. And try to download all log and filter later. the filter itself has some problems on and off
3 hours ago
when you have trouble downloading some part of the log, a better way is to download everything without filtering
also, try both app and browser
