12-12-2023 09:37 AM
I just ported my number to Public Mobile 4 days ago. However the call display function is not working for me, all the calls I receive is showing "No Caller ID". I have tried restarting the phone and turning the caller id feature on and off in Settings. I have an iphone 13 and using a public mobile Esim.
12-24-2023 08:44 PM
Issue resolved
Turned out my service wasn't fully activiated yet. I could make outgoing calls and have 5G data but wasn't able to receive incoming calls and get call display. I contacted a customer rep and he was able to do a reset on my account.
12-12-2023 10:14 AM
Maybe update to the most recent IOS if not done already.
Public mobile has been sending reminder emails to customers to make sure to update IOS to be able to use all the features on the phone and PM service.
12-12-2023 10:01 AM
Unfortunately I am using an esim with my Public Mobile subscription
12-12-2023 09:59 AM - edited 12-12-2023 10:02 AM
@buriburi And is it possible for you to try the SIM card in another phone to test ? And if you can can you try the other person SIM card in your phone to test this will help determine if it’s account issue or device issue
edit sorry you mention eSIM . So you can’t . Maybe just reach out to support from my first reply @buriburi and ask them to reset your account
12-12-2023 09:58 AM
Thank you for the quick replay Handy. I tried the network settings reset but still doesn't resolve the issue. It happens to all incoming calls even those that I saved in my contacts
12-12-2023 09:42 AM - edited 12-12-2023 09:44 AM
@buriburi PUblic mobile doesn’t have call display . It will just show the number calling . But if you have that person in your contacts it will show the name of persona calling /texting you . If you’re not even getting that maybe reset network settings see if that helps . Also can you put the sim. Card in another phone to test ? If same use this link to support to investigate
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
