01-23-2025
02:09 PM
01-23-2025
02:16 PM
computergeek541
Hello,
Over the past week, I've been getting hit with a lot of BS calls. Can you PLEASE add call control to the features of PM?
I'd be more than happy to pay extra for it.
Thanks.
02-10-2025 02:52 PM
Seconded! I am very tech savvy and block numbers regularly, I try all the tips and tricks except blocking unknown numbers which I am not able to do for work reasons. Call Control makes such a big difference, and I would happily pay extra for it each month! Please consider developing this feature!
01-23-2025 02:44 PM
There are not much you can do about spam calls because the number are spoofed probably not their actual number.
You can use the Truecaller app but I didn’t have much luck with this app. Spam calls still get to me.
01-23-2025 02:14 PM
Maybe it's in the works, maybe not.
Use the chatbot to voice your opinion of this to Public Mobile.
I enabled this feature at Koodo but without me removing it, it only worked for 2 days and then stopped. When I inquired of them they couldn't explain why it stopped working.
01-23-2025 02:12 PM
sorry @RL_CND
PM does not offer that. If this is a much needed feature, you might need to go with Koodo or Telus
