06-04-2023
06:40 PM
06-04-2023
07:21 PM
computergeek541
Hi,
I just registered a new PM SIM card. I'd like to get back my old public mobile number that was deactivated in January. How can I see if its available and then transfer over to this number?
Thanks,
Sara
06-04-2023 07:07 PM
Thank you.
Its a public mobile number as it was one offered to me when I registered my last SIM card.
I just called it and it said number not in service so I'm hoping its up for grabs.
Thanks for you help.
Sara
06-04-2023 07:02 PM
@Sara84 one thing to note. if the number you want to get back was originally from another provider and you just ported into PM, then PM support would not be able to assign you back the number. The number would have been back to the original provider where you got it from in the beginning.
However, if the number you want back was from PM/Koodo/Telus originally, then there is a slight chance you can get it back, given that no one has taken it yet
06-04-2023 07:00 PM
Good idea, I'm going to try! Thanks
06-04-2023 06:59 PM
Thank you, I'll look into this 🙂
06-04-2023 06:48 PM - edited 06-04-2023 06:51 PM
@Sara84 If you can’t get it back , you should know you can change your number 4x in a 30 day cycle in your my account
Change # on profile tabs
And you can search thru different available numbers
06-04-2023 06:43 PM
Have you tried calling that number to see if someone else has it?
06-04-2023 06:42 PM - edited 06-04-2023 06:42 PM
06-04-2023 06:41 PM
..also I kept getting an error message when trying to submit a ticket about this.
