@CS_Agent
El4035
Hello I purchased a Public Mobile plan and selected ESIM activation but the app shows my device as not compatible with ESIM even though my phone is compatible Device Motorola Edge Plus 2023 IMEI 354715630422348 ESIM supported VoLTE supported 5G supported Live Chat asked me to contact CS Agent for manual ESIM provisioning Please activate my service on ESIM or provide a manual ESIM QR code I already paid for the plan and want to proceed with the original ESIM option without buying a physical SIM Thank you
2 REPLIES 2
hi @El4035 we are just customers, please remove your IMEI number
and you need PM agent to helpy, you can  submit by direct message:
Dunkman
@El4035
Did you receive email with QR code for eSIM?
If not, you will need to contact customers service agent:
Send a ticket via the chatbot to customer service agent (CSA) via link:
If that does not work,
Send a private message to CSA through the following link :
