06-19-2023 02:38 PM
I would like to cancel my old number so a payment doesn’t get taken out for it. i lost the sim card and phone. can’t log back into that number without having a code sent to that number.
06-19-2023 02:47 PM - edited 06-19-2023 02:47 PM
Did you create a Eversafe ID? If you haven’t, you need to create one first then login. Click on Sign Up and create an ID.
06-19-2023 02:45 PM
i can’t get into that account at all
06-19-2023 02:44 PM
HI @dmj-
Try to submit a ticket with CS agent and ask them to disable the Pre-authorized payment for you, or even remove the credit card:
06-19-2023 02:42 PM
You can login to your account and go to Profile section and click on Lost or Stolen Phone to stop payment. You can also diable AutoPay until you get a new phone and SIM so you can retrieve your old number back.
06-19-2023 02:39 PM
if you know the 4 digits account PIN, you can call 1.855.4PUBLIC and disable Autopay there
If not, you will then need to login to My Account to complete that
PM just changed to a new EverSafe login system and you need to complete the setup
I assume you have not created an EverSafe id yet, you won't be able complete the part to link your My Account with the EverSafe ID, that needs a working phone with a working PM sim using SMS. (Sending the code to email would not be a choice until EverSafe id is fully setup)
Try these workarounds, it could bypass the SMS in linking My Account with EverSafe ID
If none of those workarounds helps, please open ticket with support and have them to help in this situation:
