08-29-2023
08:30 AM
08-29-2023
02:36 PM
computergeek541
@CS_Agentyesterday I initiated a phone transfer process but recieved the following message a little later (Aug 28th 21:27 CST). No one has contacted me yet.
Hey, it's Public Mobile. We're having trouble transferring your number. Looks like you entered an incorrect ESN/MEID. Someone from our team will contact you shortly using your original phone number or the alternate number provided. You can also get in touch via our virtual assistant at:
08-29-2023 08:36 AM
it is better to use account number instead of IMEI for smoother porting experience
and instead of waiting for them to reach out to you, there is a number to call to talk to live support. You can update them the correct information and they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fix
08-29-2023 08:33 AM
@MKC10 Best to only use old provider account number and not the IMEI . Will send you number for live support to re trigger the port request .private message and got it fixed
