06-04-2023 09:25 PM - last edited on 06-11-2023 11:29 AM by Dunkman
Looking to port from Koodo. It wasn't an option on the transfer page carrier select/drop-down, so I selected Telus.
My IMEI number also wasn't recognized.
Submitting a ticket didn't work (the page was broken).
I saw some advice to activate a new number and then put in a request to @CS_Agent to help with porting the Koodo number.
Now I'm paying for two numbers.
Help?
06-06-2023 02:32 PM
@James5542478 Thanks for sharing with Community. Customers who are specifically porting in from Koodo will need to contact our Customer Support team to assist with the process.
06-04-2023 09:40 PM
@James5542478 if your Koodo post paid , there’s a number for live support that can re start the port request .. will send you private message just in case
06-04-2023 09:30 PM - edited 06-04-2023 09:35 PM
@James5542478 , when trying to submit a support ticket through the virtual assistant/chatbot please use a browser in private/incognito mode (preferably on a computer/laptop).
When porting your number over you use your current providers (Koodo) account number not the IMEI of your phone otherwise there’s usually issues! Sorry!
You can Click here to submit a ticket↗ through the virtual assistant. “This method uses the ticketing system for a faster response time”. Use a browser in private/incognito mode (preferably on a computer). This works for me as of tonight!
Alternatively, You can send a private message to a CS_Agent: -> https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437 “This method takes longer to receive a response back”.
Customer Support Agents are available from:
A CS_Agent will respond back in your Community mailbox at the top right of this page (envelope icon to the left of your community avatar).
06-04-2023 09:27 PM
@James5542478 If it’s Koodo pre paid you need to activate first then get support to help port number over … if it Koodo post paid you should be able to do it on you my account
Message support directly
