09-26-2020 01:34 AM - edited 01-05-2022 01:21 PM
I SEE THE LONG DISTANCE ADD-ON MENTIONS THE UNITED KINGDOM, BUT NOT IRELAND (SOUTH IRELAND IS NOT IN THE U.K.). If I purchase the long distance add-on, will the add-on include Galway in South Ireland?
Thanks.
10-08-2020 12:15 PM
@JoyLuck It's my belief that the 300 minute add-on is programmed as a new offering. I would not be surprisred if the old 400 munute add-on uses the old country list.
10-08-2020 12:12 PM - edited 10-08-2020 12:19 PM
@BassBoy7 wrote:I SEE THE LONG DISTANCE ADD-ON MENTIONS THE UNITED KINGDOM, BUT NOT IRELAND (SOUTH IRELAND IS NOT IN THE U.K.). If I purchase the long distance add-on, will the add-on include Galway in South Ireland?
Thanks.
Ireland has now been added as one of the countries for International Long Distance
300 International Long Distance Minutes
09-26-2020 09:44 AM
You can also use Wi-Fi apps like Google Duo, Skype, Fongo, and FaceTime.
09-26-2020 09:29 AM - edited 09-26-2020 09:31 AM
@jor123 yes. As long as you have a wifi connection can use it anywhere in the world. The app is many people's go to app when they travel to other countries.
Unlike apps like WhatsApp where both parties need the app. Textnow only you need the app. So easy for elders to reach you. Just pick up the landline and dial your textnow number
09-26-2020 09:26 AM
Interesting, are US/CA calls even free on text now?
09-26-2020 05:27 AM
@BassBoy7 check out the app called TEXTNOW. You get a free Canadian number in your area that allows you to call Canada/USA, text (even has voicemail) over wifi for Free. Can use data as well.
Textnow offers really cheap rates for calling other countries.
Looking at Ireland it actually says it's a FREE call. Not sure if it's Ireland cell numbers or landlines but it's worth a try.
09-26-2020 02:22 AM
Thanks ... I thought as much
09-26-2020 01:41 AM - edited 09-26-2020 01:43 AM
@BassBoy7 No, it won't work. Ireland isn't U.K. You'll need a calling card or use an app to make calls.
09-26-2020 01:37 AM
@BassBoy7 It will not be able to go through.
