01-22-2025 01:29 PM
Hello..help! I am trying to buy U.S. roaming 15 day talk, text, data. Usually $30+ tax.
I just finished my last 15 day same pkg yesterday but are having great difficulty today
buying a new 15 day roaming. When I select it, it adds funds & then I try to purchase my 15 day but does not seem to purchase. I even checked Usage Breakdown & it shows 0 / 15 days left?
Add-Ons
01-22-2025 01:37 PM
There is a time limit from when you can re-buy the same add on, you may have to wait 24hrs and then try again.
01-22-2025 01:32 PM
yes, usually you need to wait 24 hours before you can re-buy the same roaming addon .
you will probably need support agent's help to sort this out. Please submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
