Bought two U.S..add ons by mistake. Can I cancel one?
mikehalif
Please let me know how to cancel the second U.S..add on I bought by mistake.....
I'd like a refund.
2 REPLIES 2
Phil_Adelphus
@mikehalif  You typically can't buy two of the same add-ons at the same time (although, is this US roaming or long distance minutes?) .  If both are the same US roaming add-ons are you sure both went through?   The only way to get a refund is to contact customer service, open a ticket at the chat icon bottom right of this page, but if that doesn't work use the private message link already given by @TheSterlinger
TheSterlinger
@mikehalif
 Once you add an add-on you cannot go back or cancel it. Unfortunately you are stuck with. You can try submitting a ticket to a Public Mobile but most likely will not get a refund.
To check your message click your avatar then messages or click the envelope icon.
