Bought data add on but not showing up
Salomon
I bought $15 of 1GB data add on, but data doesn't show up. I need it badly but I am unable to use data since yesterday Sept 14, 2021.
@Salomon wrote:
Solved. Thanks
Salomon
@Salomon
glad it worked out
enjoy your service...
Salomon
Solved. Thanks
Salomon
popping
@Salomon
Buying add-on is a 2 steps process:
1.  Add fund to your account
2.  Purchase the add-on.
If the amount of available fund on your account is equal what you just added, you need to purchase the add-on using the fund in your account.
@Salomon
sign in to Self-Serve, to review your account, if you found at Available Funds: $ ?
Try To Purchase Add-Ons Using Your Self-Serve Account
To purchase Add-Ons using your Self-Serve account, follow these steps:
  1. Click on ‘Purchase Add- Ons’ on the Overview tab and scroll down to the Add-On calculator.
  2. Click the plus sign (+) to add and the minus sign (-) to remove selected Add-ons.
  3. When you’ve added all your desired Add-Ons, click ‘Buy Add-Ons’ or ‘Make a Payment’ below the calculator:
    • You will see ‘Make a Payment’ instead of ‘Buy Add-Ons’ if there are not enough funds in your account to make the purchase.
    • If you don’t have sufficient funds to purchase the Add-Ons, you will be asked to make a one-time payment equal to the price of the Add-On, less your current available funds. Click ‘Submit’, then ‘Go back’: now the button below the calculator will say ‘Buy Add-Ons’.
  4. Select ‘Confirm my purchase’, and you’re off to the races!
  5. after you Add-on you have to do Rebooting your phone
    what is mean for Rebooting the phone means to turn off your phone and turn it back on again.
Overview Of Add-Ons visit Here link.
